Hello there,
After restarting my PC this error appeared when I tried to open Winamp player. It worked just fine before restarting and now I don’t know what happened. Can anyone help me please to fix this ? Reinstalling is not working, I did this many times.
Thanks !
Nullsoft Direct Sound Output v2.6
Error creating DirectSound buffer.
Error code: 88780096
OK
Winamp error creating direct sound buffer output
Hello Darrell,
Did you update any drivers or any kind of system change before restarting the computer.Please try below solution.
Open Control Panel >> Administrative Tools >> Services. Browse the service and find the one named "Windows Audio". This one basically controls and manages all your audio devices. There might be a chance that due to any update you made this service is stopped. Set the Startup property to "Automatic". Now each time your computer reboots it will start automatically.
Good luck..!!
