Winamp Library Sort Albums by Years
I need to execute winamp library sort albums by years in the Android operating system.
Can anyone suggest a good tutorial I can easily understand?
Thanks. Â
Thanks. Â
Hi scott? This is very simple. You can do this using the play queue which allows you t sort out your song the way you want. Follow this sit to see some screen shots. https://www.getwinamp.net/mirror/website/BLOG_WINAMP_C/2011/01/11/WINAMP_FOR_ANDROID_PLAY_QUEUE_T/INDEX.HTM
I hope this helps you out.
To sort media, you need to open Winamp, right click on its menu bar, select "Media Library", click "Audio" drag and drop media into the window next to it and then click the third button, "Pane options".
In there, you can add "Year" column if it's not already present. Then click on the "Year" title above the media to sort by the year.
