Hi! I’m using Winamp for playing videos and it’s nice, but this time whether I play or not the error appear.
I don’t have yet the copy of installer for me the to re install the program.
Do you guys have another idea how to fix this problem?
DDE Server Window: winamp.exe – Application Error
The instruction at "0x61cd82f8" referenced memory at "0x04bd1ff0". The memory could not be "read".
Click on OK to terminate the program
Winamp player application message error
Hello Honey Daniels,
It seems like your winamp player has been corrupt . The registry settings may be missing or have been corrupt due to an infection by a virus some modifications that you could have made to them without knowing.
The solution that I will suggest that you use to fix the problem is by getting another winamp setup and installing it. You should be worried about where to get one because there are plenty of sites online that you can download the setup for the winamp player from. Some of them include cnet downloads, softpedia. You can also try btjunikie.org
Hope this helps.
__
Regards
Clair Charles.
