Winamp player audio Enhancements Problem
Hello there,
This morning this error appeared when I opened Winamp Player to listen some music. Last night it worked just fine and now this error confused me a bit and I don’t know what to do. I click NO and the Winamp is not opening anymore. What would happen if I click Yes? Is this an error and I should be worried about? Thank you!
Audio Enhancements Problem
Windows has detected that audio enhancements for the following device are causing problems:
Speakers (Realtek High Definition Audio)
Would you like to disable Driver Enhancements for this device ?
Yes No
