Winamp spat out this odd-sounding error
Winamp USF Player – When playing USF files (N64 music rips), Winamp spat out this odd-sounding error. Help Please! Thanks.
Error
Track and AilenChanged but audiolsPlaying not set
OK
Error
OK
It seems like the value returned in the Winamp script is false by default which means its not set. The problem may be rooted from the Options menu of Winamp. Try to restore the default settings and restart.
This may happen also because of the recent changes you made to your registry. Run registry repair tools such as Registry Mechanic to fix all registry entries.
Hi Gary,
The problem with this issue is that firstly you may have forgotten to install a certain DLL file that will help WINRAR to play the USF file.
Secondly you may have not ripped the file properly hence the error.
Last but not the least, some versions of WINRAR do not support this format at all, so you should be careful and update your version of WINRAR first.
Notifications
