Window 7 software PDF application download
I am using a window 7 operating system, what software OR
Application should I download for me to open a PDF file format?
Here is this very well-known software named Adobe Acrobat Reader. It is completely free and supports Windows 7 fully. You can get it by clicking on this link Adobe Acrobat Reader. It is quite easy to use and can open any kind of PDF file. It also supports searching, printing verifying and other options which are its advantages.
During installation of this software you have to keep one thing in your mind. I-e to temporarily disable your antivirus(in case if you have installed any in your computer). However once you are done with the installation of the software, then of course you can enable your antivirus back again.
To open a PDF file in any operating system, you need to install a PDF Reader. This is the program used to open a PDF document. There are different brands of PDF reader available. The most popular one is the Adobe Reader. The latest version is Adobe Reader XI 11.0.04 and the one I’m using is version 11.0.4 which means I need to update.
Another brand that you can use aside from Adobe Reader is Foxit Reader. In Adobe Reader, you can do some other stuff like inserting a comment, putting a stamp, and more but you cannot create your own PDF file. It does offer you option to create a new PDF document but it is done online and it is not free. It is on a per subscription basis.
If you want to signup for a monthly plan, it costs around $10 a month. If you’ll be having an annual plan, it’ll cost $7.50 per month. With Foxit Reader, you can already create your own PDF document without subscribing for a plan. The free version is already capable of creating a new PDF document unlike with Adobe Reader.
It is integrated with a free PDF creator that allows you to create standard PDFs that are completely compatible with other PDF products. Download the latest version from Foxit Reader 6.
