This morning I had this error and now my Software Center it doesn’t work at all. I tried to reboot, reset and nothing is working. Can you help me to fix this error? Can I restore somehow so that my apps and software center work again?
Thank you!
The window "Lubuntu Software Centre" does not seem to be responding. Do you want to force it to exit by sending the terminate signal?
Cancel End Process
The window “Lubuntu Software Centre” does not responding
I think this error on your Lubuntu Software Center is one of those little annoying bugs in Lubuntu which can be experienced if you happen to be using the non-released version of Lubuntu. The most common error on Lubuntu Software Center is receiving the error “Lubuntu Software Center not working” which appears when you start Lubuntu Software Center.
Though you have a different error on Lubuntu, you should verify if this error is the known problem. To do this, run the following command in the terminal without quotes then hit Enter: “lubuntu-software-center”. If the command returned lots of errors about python, run the following command without quotes then hit Enter: “rm -r ~/.config/lsc”.
This command will force Lubuntu Software Center to reconstruct or rebuild next time you open it using the menu. Rebuilding Lubuntu Software Center can take some time and just wait for it to finish so you won’t have any problem again.
