michaeltaas
Posted on - 09/13/2011
I am using Movie Maker from long period. I created many movies in this program. But today I want to import .wma file in movie maker but when I give this command to movie maker it generates error for me. Error detail is given below. Any one tell me its solution.
Window Movie Maker
The file D:Documents and SettingsJake LudingtonMy DocumentsMy Music The Rolling StonesSingles 1965-1967 11 Paint It Black. wma is protected using digital rights management and cannot be imported.
                                                           OK
Windows Movie Maker file import error
Hi
This is a common error you find in media player. Actually this is not error this is just a warning message to use by the media player to inform you about the situation. This problem may occur when you are trying to ripping the audio you have used in your movie making project.
If you have turn on the option called Apply digital rights management while you are ripping a movie this warning message will be displayed. Only option you have to fix this problem is re-rip the audio track. But to do that first you have to write the audio track in to separate CD and re –rip it from that. This may solve your problem.
