Window problem about speakers sound
My speaker is not producing any sound after installing new window please help and tell me what window is best window 7 or 8?
Sound problems are also caused due to improper hardware setting. Make sure that your speakers are properly plugged in and check the sound card and volume.
To check your sound processor or sound card is working properly,
1. Click on Start button. In it, click Control Panel->System and security->System->Device Manager.
2. If you are asked for administrator password, provide it with it.
3. Expand Sound, video and game controllers.
4. If it displays Sound card, then it is installed in it. If it does not display, then you probably need to install it according to manufacturer’s instructions.
5. If you have installed sound card but it is not displayed under Sound, video and game controllers, check in Other Devices.
