Window size issue on Windows 7
I used Windows 7 with no issues. But when I tried to move any window to the border of the screen, it automatically resized to half of the desktop size. What is the reason for this?
I am waiting for any suggestion.
This is a characteristic in Windows 7 where if it moves the windows in the top part to maximize that windows and if you changed to the basic sides the window of this side. This is normal. If he(she) does not like the function, it can deactivate it in Beginning, and go to all the programs, choose accessories, click in center of accessibility and facility of access. To go to the low(lower) part of the window and search to make it easier to center on the tasks. Another screen is opened, go to the low(lower) part and verify to prevent that windows are organized automatically when it moved up to the rim of the screen. Touch OK (Accept).
Thanks. .
Hello Ruth Penn,
It could be a problem with the resolution settings of your screen. You should know what inches your screen and then set the right display resolution for it. Just use the steps below to check and adjust the resolution settings of your screen in case they are the ones causing problems.
In the blank space of your desktop, right click and then choose screen resolution. You should see a screen like the one below:
Adjust the resolution as you check what effect it has on the screen until when it becomes fine for your screen. You may adjust the orientation of the screen too in case it is not right.
Regards
Clair Charles
