I have Windows 7 32 bits on my computer. I have installed DX and WindowBlinds on it but I always get an error every time WindowBlinds is being used and starts up DX. However when I disable WindowBlinds and run DX, it runs without any problems. Does anybody have a fix for this problem?
Thank you.
WindowBlinds error when used with DX
Hi Bryan,
This problem comes because of several reasons, you can check there is some problem with your RAM, Device drivers are damaged, Registry is corrupt and virus.
But the one concrete solution I have, check this one on store.stardock website if your already register sign in or Sign up and make new account download DX version 3.5 (non-beta) after installing this version your problem will definitely solved.
