I was trying to run sfc scannow when I noticed that something was wrong with my computer. To my disappointment, even the sfc scannow failed. I am using the Windows 10 operating system. Windows 10 sfc scannow not working can someone help?
Windows 10 Sfc Scannow Not Working
The sfc scannow is a Windows command that is run on the command line. Sfc scannow is a command that scans the system for problems and fixes them. Much like you, many users have reported that sfc scannow is also failing.
This can be due to viruses and corrupt files. The first thing you should do is scan the entire computer for viruses and malware. If it is clear, then there is no other option but to repair all the corrupt files. One thing you can do is to restore the system to a previous working version. Then try to make the updates that you wanted.
