Hi Everyone,
I want to know what is the minimum system requirement to perform clean install of Windows Server 2003 enterprise edition 64 bit. Also tell me how do I obtain Microsoft Windows Server 2003 service pack 2 for latest updates.
Please help me on the subject of windows 2003 enterprise 64. I would appreciate your help.
Windows 2003 enterprise 64 bit?
Hello Markusa,
As Microsoft’s say Windows Server 2003 delivers better performance than Windows 2000. A great news is that the compatibility mode of the Windows Server 2003 allows other applications to run with greater stability. Here is the system requirement for you:
Windows Server 2003 – Enterprise Edition
Minimum CPU Speed – 133 MHZ for x86 or 733 MHZ for Itanium based
Recommended CPU Speed – 733 MHZ
Minimum RAM – 128 MB
Maximum RAM – 32 GB for x86 or 512 GB for Itanium based computers
Multiprocessor support – Up to 8
Disk space for setup – 2 GB
You can search or get the latest updates from the Microsoft Support Center.
Good Luck.
