Nicki Hill
10 points
Posted on - 06/26/2012
I am using Windows 2003 Server which is connecting to a network of 6 computers. How can I keep my kids to go over the reference registration time? In other words, how could I set up the server to close the session when recording time depends on?
Windows 2003 Server to a network of 6 computers
If you have a router placed between these 6 computers and the main computer then you can use it to restrict the access to each computer.
Just go to the routers page on 192.168.1.1, set the time stamp that from this time to this the child will be able to access the internet or the network and after that the network will be disconnected.
If you are using Windows 7 then you can also use Parental Control from each of their systems to do such things. You can set the timings from there; restrict the internet usage and access to other computers over the internet and all other things that you can think of. Just go to the manage accounts from the Administrator account and you are good to go.
