I need to load Direct X into Windows 7 but I do not know how to go about it. Okay, I need to install call of duty and I have everything installed but it keeps asking for Direct X. I have the drivers downloaded and installed but I do not know how to load them. Please help me do this.
Windows 7 and Direct X Problems
DirectX is one of the legendary products of Microsoft for gaming for Windows platform. It provides maximum performance and usability of hardware resources on PC, enabling direct access to them. Almost all the games today developed for Windows is developed with DirectX.
DirectX is available to be installed in your PC. Download DirectX. Offline installer is also available. Download DirectX Redistributable.
After downloading, run the installer and DirectX will be installed in your system. Then, all the games will be available to be played.
Drivers don't need to be loaded. They automatically loads while Windows boots up. They're running silently but effectively that enables you have your PC run smoothly.
