Windows 7 and sdhc card file recovery
I need to copy Windows 7 in my SDHC card and transfer to another computer to install Windows. What process will be beneficial that extract all the SDHC card file recovery and install on another computer?
To copy windows 7 in your sdhc card and install it in another computer follow the steps below:
1. Make sure that you have an sdhc card that has enough space to copy all your system files. A typical backup can be around 10GB-15GB depending on the data stored on your computer. So make sure you have a card with enough memory to contain all this data.
2. Using a card reader connects the sdhc card to your computer.
3. When the auto play dialog box pops up, select "use this drive to backup files".
4. Then follow the instructions and click start back up.
5. The backup process will start which will save all your system data on the sdhc card. See the screenshot below:
6. After the backup is complete you can eject the sdhc card and then connect it to the computer that you want to install windows.
Hope this information helps you.
If you simply want to copy your system drive where Windows 7 is installed and put it on another computer, the easiest way is to clone your Windows 7 system drive. This images the system drive or drive C where Windows 7 is installed and creates an exact copy of that drive with the Windows 7 operating system intact. You can do this with EaseUS Partition Master.
Download the latest EaseUS Partition Master Home and install it. Once installed, insert your SDHC card and start EaseUS Partition Master then click “Wizard” and then select “Clone disk wizard.” On the next screen, select the source disk or drive you want to clone. Here, select drive C where Windows 7 is installed then click “Next.”
After this, for the destination disk, select your SDHC card then click “Next.” Click “Yes” to confirm. This will delete the entire contents of the SDHC card. Resize the partition on the destination disk or the SDHC card then click “OK.” To preview the result, click “Pending Operations.” If they are right, click “Apply.”
