Windows 7 antivirus to prevent access
Can the Windows 7 Antivirus integrate into the system to block Internet or network access upon detecting a virus or threat that could not be contained?
Windows 7 provides better security for the users whenever you access any file or link which can harm your computer. Windows will display a message and ask you for permission. It then depends upon you to allow or reject the access.
If you want to access the file window and do not show the message again and again, you have to make an entry in Windows firewall that Windows is able to recognize them and not ask for permission again and again.
You can install Internet Security software to avoid any virus. Windows 7 has not that such facility.
I would suggest you download AVG Antivirus and internet security.
