Windows 7 is a complete OS
Are the Microsoft windows 7 is a complete Operation system, can it installed independently on at any compute or require prior copy of windows installation, if required can it available for download as an ISO file .
Yes, Windows 7 is a complete Operating System. Therefore it can be installed on any computer. Of course you need a CD for you to be able to install it. You might think that you can use pirated copies of Windows 7, you are wrong.
Even if you are able to find a pirated copy of Windows 7, you still need an original copy. Why? It is because Windows will prompt you during the installation of the OS that you need to enter a product key.
Only an original CD of the OS have the proper product keys, but I doubt that you'll be able to find one. Windows 7 OS cannot be downloaded.
Windows 7 computer is up-to-date is considered a perfect OS for Windows. But there are features that this type of Operating System needs some updates, or else needs to add features. Let's say Mac OS, the new version. It has this itouch screen built-in of the actual hardware. While Windows 7 doesn't have this feature. But for sure, Windows 7 is the best Operating System up to date because of feature and it's functionality. I prefer using this type of version rather than the older version or other type of Operating System.
The Mac operating system, Lion has an added feature for easy access. Touch screen and other software and hardware component, specially the additional apple apps specially designed for specific usage.
It has this reliability that can be easily understand and it's 100% user friendly.
