Windows 7 desktop icons issue
There are some problems with the desktop icons of my computer as my PC shuts it down automatically and after restart the icons are huge.
Am I supposed to do re-installation of OS?
No, it is not really required to do re-installing your OS.
Just go to your Desktop and try one of the following combinations to decrease your icons size,
1. Press Ctrl and Scroll down with your mouse.
2. If you are not having Scrolling option in your mouse then use Ctrl + Minus sign to decrease icon size.
This might be helpful for you.
Open device manager to see either the device is put in or not by checking show driver. Power disruption can be the origin of crooked drivers.
For device manager:
For Adjusting screen Resolution:
