Windows 7 DVD to USB Drive: DVD copy programs for Windows 7
Hi.
I want to copy the programs from my DVD to the USB and convert it into USB. What are the steps for DVD copy programs for windows 7? Please reply ASAP. Thanks in advance!
Hi.
Hi. The steps for DVD copy programs for windows 7 are as stated-
1) First, the USB flash drive should be connected to the computer USB drive
2) To format the flash drive, click on my computer>select format after right-clicking on USB drive
3) Start>run>command-prompt and type the command- convert:i/fs:ntfs where I is the USB drive end
4) Now the Windows 7 iso should be mounted as a drive
5) Start>run>command-prompt and type the commands again- mbrwiz/list to know the disk number of USB pen drive, mbr/disk=x/active=x where x is the disk number of the USB drive
6) Start>run>command-prompt and enter the command- J: -> CD boot->bootsect/nt60 Y where Y belongs to the drive end of the USB drive
7) Wherever the files of Windows 7 iso have been mounted, they should all be copied.
8) Reboot the computer. Select F9 and select USB drive as the boot drive to get the binary input output screen
Hope we helped.
