Windows 7 features-need help on this
I am posting a image below. This is a visual feature of windows 7 which is functioned with (windows+tab) this buttons. However it is not working in my windows 7 right now though it was few days ago. In my job I have to which windows quickly and I use those keys to do so but now this function is not available and I am in some serious predicament. Please, someone help me with this problem.
Kenneth Feugo
Answered By 15 points N/A #116939
Make sure that all your Win Key is functioning properly as well as your Tab key. If all is working, try troubleshooting the transparency and visual effect of your OS.
  1. Click Start Menu.
  2. Type Aero on the search bar.
  3. On the result under Control Panel, click Find and fix problems with transparency and other visual effects.
  4. Follow the troubleshooting steps.
The troubleshooting wizard will try to fix and detect any issue related with Aero capability and make changes to if needed.
Items with red x indicates that a problem was detected that might cause the problem with your Aero Flip 3D. Try to re run again the wizard if cannot be resolve.
