I am using window 7. I have many folders which I want to secure using win7 I try my best level but I can't do so. Please if anyone know about windows 7 folder password protection freeware please tell me and suggest me how can I do.
Windows 7 folder password protection freeware
Hi Ingridgonzalou,
I searched some solution that may help you with your problem:
1. Make a new folder.
2. Open the folder and inside it right click on an empty area.
3. New > Text Document.
4. Open the Text document you create inside the folder then Copy and paste this code you will see in this site:
5. On the code you will see Password goes here, edit it with your password you want.
6. Save it with the filename locker.bat.
7. On the save as type choose all  files.
8. Inside the folder you will see a private folder. there you put your files you want to protect from others.
9. Click locket.bat file and will prompt you with a question. Just press Y then enter.
10. If you want to see the folder again just click locker.bat file then input your password.
There you go its done.
Hope this information will help you.
You wanted to secure your pc for privacy or secrecy reasons.
You can try some password protection software or some processes to get the security. This link shall get you to one such solution.
You can also try this software.
