Windows 7 get this iexplore.exe – Application Error
I get this error now and then without any reason.
Any ideas?
Any ideas?
The reason as to why you are getting that error could be probably because of an ActiveX control on a web page that you are visiting when you get that error. What the error message essentially states is that the instruction that is at the executing address, and that means at0x62304320, may have attempted to read from the same memory block that is currently executing. In other words, the instruction may have tried to read 2x, at the exact same moment on the same location which cannot allow that to be done.
What I will suggest that you do is contact the support staff to the website which you encountered the error while accessing and notify them about the error.
-Experttechyv
Hi.
To fix this issue, it is best to uninstall the BHO that is causing the error.If you are not sure which BHO has generated errors, eliminate them one-by-one. When you discover the BHO that is causing the error, you must remove it and if you want you may reactivate the other BHOs , some EXE errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date
