Hall Allen
80 points
Posted on - 10/03/2012
I've tried almost every possible remedy I've read over the Internet and still not working. My last resort is to reinstall the operating system which I really don’t like to do! Could it be a virus? Spyware? Or corrupted registry? Is there like an ON/OFF thing for Windows 7 hidden keys?
Windows 7 hidden keys are not working
Hello Hall Allen,
You have tried almost every way to get your solution but didn’t get. There is a system to enable and disable of windows hidden keys. You will more information about this from below site. To get more information please click the following link:
There has large discussion about this solution.Â
Hi, Hall Allen
I know why on/off Windows 7 key. But I can say something that If you want to on the Windows 7 hidden key.
1. Go to Computer properties.
2. Then select the hidden file what you want to own.
3. And then click show the hidden files.
Then your problem has been gone.
