Hi, I got this copy of windows 7 key finder from dvd that i bought on local vendors and i wanted to enter these keys on my windows 7 operating system. Could somebody tell me how this thing work?
Windows 7 key finder from dvd that i bought on local vendors
Hello Mikhail,
You will simply have to run the setup application to install the Key Finder. If the installation files are in a folder, look for a file named setup.exe and then double click on it. The installation will begin immediately and then you will just follow the procedure till it finishes.
Nicke
Window 7 key finder is an application used to locate the product key of a window 7 operating system that was installed previously on your Computer. If you lost your product key, you can recover it by following this procedure;
1. Run the key finder application on your DVD by locating and double clicking setup.exe file.
2. Follow the software installation instruction accordingly.
3. At the end, the program will display a series of letters and numbers formatted like this:
xxxxx-xxxxx-xxxxx-xxxxx-xxxxx. This becomes your window 7 product key. Copy this character out exactly the way they are and use it when installing your window 7 operating system.
Note: If this fail, request another key from Microsoft or purchase another copy of window 7.
Alfaro.
