Windows 7 login Password Locked
You can try to unlock your password by trying these simple following steps:
Click the restart button on your computer, then press down F8, open the Window Boot Menu, click the “Safe Mode with Networking” then choose “Default”
Log in with the Administrator you can leave the password blank, after using that account, you can now enter Windows. Right then launch the “Control Panel” click the “User Accounts and Family Safety” and select the “User Accounts” After selecting “User Accounts” click the “Manage another accounts” go to your “Original User Account” then select Remove password” ,and lastly, restart your computer.
You can get your password also by insert your reset CD, the one you had created when you first got the computer and this will reset the computer to the factory defaults.
When this is done, then you can imput a new password into the computer.
You can even leave your password blank for easier log ins.
If none of these work and you never created a reset CD, then you can take it to the computer to have them reset windows for you.
Good luck =)
I have met a problem with my Dell Win 7 password. Refer to Google search:
Get exact tutorial suggestions from search results.
The tips tutorial supports following methods:
Option 1: Dell Windows 7 password reset by other accounts with admin rights
Option 2: Recover Dell Windows 7 password with command
Option 3: Create a bootable Dell Windows 7 password recovery disk
Losing Windows 7 password is not such a trouble thing if you handle it in a right way.
No worries when you forget windows 7 password.
The article will give you some ideas to reset Windows 7 password USB flash drive
