Windows 7 open apache monitor problem
I was using vista for a long time. I switched to windows 7.
I am using a Apache monitor and it was working fine with vista, but windows 7 is showing problems with the monitor.
Is it a software problem or a hardware problem>?
Best Answer by Edmund Joseph
Answered By 0 points N/A #138315
Hi Bettyfcampbell,
This is the problem of that software. It is incompatible for Windows 7.  You should choose the updated version of Apache Monitor offered for Win 7. There are many forums on Apache, where you will learn more about it.
For instance, http://www.farinspace.com/php-error-faulting-module-name-php5ts/
Here you will find the updated version.
The download link:
http://windows.ee/win7-hslab-http-monitor/jcjlkctp.html
Answered By 5 points N/A #138316
Hi there user:
It’s a software problem. Download Apache 2.4.1, this is supported with PHP 5.4 install from windows.php.net.
Extract it to the root of C: and it will be C;Apache24 when done.
Run it with PHP 5.4 Thread Safe.
Extractphp5apache2_4.dll-ph-5.4-win32.zip and copy php5apache2_4.dll.
This is needed to let Apache use PHP.
Hope this will help you solve your problem,
Thanks for asking,
