blackjan
Posted on - 10/08/2011
Weeks Ago so I installed Windows 7 OS Then I activated it, everything was fine.
Then about a Month ago, I went to update it and got a cannot update error message code 8004F807.
I then noticed that in the bottom right hand corner of my desktop, I have a new tag:
Windows 7
Evaluation copy. Build 7100
This copy of Windows is not genuine
I haven't installed any new hardware or anything.
Under Computers=>Properties
Windows Activation
Status: Not Available
Product ID: Not available
Any help would be appreciated please. Kindly post the link about this problem.
Thanks,
Blackjan
nizam
Windows 7 Os is not genuine Displaying Error Code
Windows 7 have 30 days trial. So it is OK for 30 days but it is needed to activate it to use for whole life. It activates it looks like the activation was not correctly done.
You have to activate it again. If you buy it from market try to give the product key in correct form see that if there any space between two letters also look at the Caps lock.
If you do not buy product key buy it from the right place I recommended you to buy it from direct Microsoft.
This the answer site of Microsoft.
Thank you
Then what you really did is counterfeiting and it will be normal once Microsoft sees it that it is not an original operating system.
Solution 1:
You can download the latest WAT Remover on the internet by searching it through Google together with the word Mediafire to make it much easier to find. But I won't recommend you do this but it's your choice not mine.
Solution 2:
You can just reinstall the trial version again and just wait for another 30 days to use it before it will tell you again that it is a counterfeited software.
Solution 3:
Buy a Windows 7 copy that is genuine and you will not have to face any of this kind of error again. This is the best solution and I recommend that you do this.
