How to personalize Windows 7
I am a Windows newbie and I just wanted to ask, how to totally personalize my Windows 7 account, like screen savers, colors etc?
Hi Carloarki,
This is one solution that I can give you.
First you have to go the start menu on the lower left of your taskbar and click on the Control Panel option; then on the Appearance and Personalization menu go to Personalization. Once you're there, you can adjust the themes, color and sound options according to your preference.
Hope this helps.
Hi there,
Your problem is easy & take a look at this solution:
Windows exhibits numerous different procedures to customize or personalize the view of your desktop. One of the tremendous things about Windows is how rapidly one can make the desktop look like your own desktop, and transform it differently from anyone else’s. When you first turn on your new computer system, you will then see the Windows desktop as Microsoft (or your computer manufacturer) set it up for you.
If you wish it to look like the way it is, fine. If not, you can manage or change it. Basically everything of Windows settings are configured along the Control Panel. You may open the Control Panel by clicking the Start button and selecting Control Panel. At Control Panel, you can click a major category, such as System and Security or Network and Internet, to access related configuration settings.
Or you can click one of the key settings under a major heading to go directly to that setting. After you click through the respective links, you eventually end up with a specific configuration utility displayed on screen. Each type of configuration setting uses a different utility, you may see a full-fledge window full of controls, or a smaller dialog box with a few options to check. Whatever you see on screen select the options you want, then click OK. This applies the settings you selected and then you are done.
Notifications
