ann tanner
20 points
Posted on - 05/30/2012
May it concern you dear?
I want to use as a dual screen with USB my two L2230 monitors. Many software of Windows 7 such as Internet Explorer and 3D max conflicts with the usb drive from cd.
The image below is what the error message shows. When I uninstall the usb drive the error disappears. Which works in windows 7, your driver problem or if you have any other usb driver.
Thank you.
The instruction at 0xf6a87404 referenced memory at 0x006eedc0. The memory could not be written.
Click on OK to terminate the program.
Windows 7 software conflictions with USB dual monitor setup
If this is the first time you encounter this error, try restarting your computer then try it again. After booting don’t open any application yet then start installing it again.
If it still doesn’t work, stop the installation then check your computer for any possible errors. Use a disk utility application to check the system.
For a more thorough diagnostics on the system, use a disk utility application like Norton SystemWorks, or Norton Utilities. Start the installation again after this.
If the same error appears again and again, you should now check the system requirements of the program you are installing. Maybe your device’s application doesn’t support Windows 7 platform.
You should check this on the program’s manual. Or you may also try disabling your antivirus before starting the installation. Just re-enable it back after the operation.
