Windows 7 stuck at loading screen and restarts
I have this problem on my desktop whenever I boot up. It gets stuck at Windows 7 boot screen before the log-in screen. After that it restarts repeating the same scenario. By the way, a clicking sound comes from the hard drive whenever it boots up. I cannot figure out what the problem is. My hard drive is a Western Digital Caviar Blue 320 GB and is barely 2 years since I bought it. Here is the photo of my hard drive and the boot screen.
Thanks in advance for any help or suggestions.
Best Answer by JeanettKoles
Answered By 0 points N/A #121952
There are two ways to solve this problem.
1. When it happens you will start your computer again. Start your computer and press F2 or F8 button to go into safe mode. Here you will find many conditions for starting your computer. Select “Start your computer from the last known good condition that worked”. It will recover your data.
2. You can restore manually from the previous time. Go to the start menu then all programs then accessories then system tool then system restore. You will face this type of box.
Here select restore my computer to an earlier time and set the time and date that you want to go back. After completing this process restart your computer.
Answered By 0 points N/A #121953
  • Just try to reformat your PC if installation can not continue maybe your hardware have a problem, check your HDD, MOBO, RAM sometimes your power supply trigger that kind of problem or maybe you VGA card is shorted so that it only stuck on windows boot up.
  • Most of the time I encountered that kind of problem, then my first thing to do is to reprogram, after that it run smoothly no stuck-up just like you encountered.
