Windows 7 system Java error
My Windows 7 computer is throwing almost 7 Java error messages. I have tried contacting Java but never got any reply. Is this problem caused because of downloading Oracle Office? Other than this my computer is found to be working fine. The numbers of the errors are as follows: 296, 4312, 2688, 3016, 3088.
How can I resolve those issues?
Answered By 0 points N/A #82513
That is a problem with the operating system. It is missing some important java components that are required for it to work and therefore you will need to fix that. One way to install the java components will be by using the windows update feature which will go online and download the java components and install it.
On your computer, you will need to go to the control panel, and then click on System and Security. In the window that will open, you will need to locate Windows Update as indicated in the image below and then click on check for updates. The updates will be sought online and therefore you must have your computer connected to the internet.
-Keegan Robb
