Windows 7 tips and tricks
Here are some tricks for windows 7 for performance.
1. Go to start search msconfig.exe and open.
2. System configuration will pop-up.
3.Click on Boot tab and then advance options.
4. Check on the box on Number of Processors.
5. Lastly choose the highest number of processors you have.(if you have 2 or more processors)
For Visual Effects on Desktop.
1. Right Click "My Computer" or "Computer"
2. And go to Advance system settings
3. Advance and then Performance click settings pop-up window will appear
4. Check only this option
Rapid Windows Lock Tips:
If you wish to instantly lock your laptop, just press the Windows +L.
For Show hidden files and folder:
If you want to view hidden files and folders, launch the Windows search box and then type folders. Select the Folder options on the search list and then go to the read tab. Check the Show hidden files, folders and drives option.
Launch Windows Explorer instantly:
Press Windows +E to instantly open Windows Explorer.
Some keyboard shortcuts:
The following are some of the keyboard shortcuts on Windows 7:
