My graphics card is Intel Graphics Media Accelerator.
When I upgraded to Windows 7 Ultimate from Windows XP, my graphics card driver is not installed.
I only have a resolution of 640X480. Searching for updated driver produced no result.
Any help finding it?
Katei94
Windows 7 Ultimate, video driver didn’t work properly
There has to be a problem with driver compatibility with Windows XP to Windows 7. When upgrading, this is a common problem that occurs and it can be easily fixed. The best way to resolve this matter is, to uninstall the current driver by Navigating to My Computer ->Right Click Properties -> Select Device Manager on the Left pane.
You can easily download the Intel G31 Graphics driver, from Intel site and double click it to install. If the problem is still not resolved you will have to format your system partition and reinstall Windows 7 in custom mode. If you got the Driver CD issued with the motherboard, it would be nice and easy. But as far as I know Windows automatically installs the most suitable drivers.
Hope this helps.
Here is a direct link for Intel graphics media accelerator driver . If you installed Windows 7 32 bit then try it.
For Windows 7 64 bit here is the link : link for Windows 7 64 bit. Hopes it will works perfectly.
Thank you.
Tahsin Chowdhury.
plabon50
1. First Go here.
2. Then Select your Operating System like this:
3. After selecting your OS, scroll down & you will see like this:
4. Select that have (exe) in last, not the (zip)
5. Then you will be redirected to this page:
6. Click on Download. Now, you will be redirected to this page:
7. Put tick in "I accept the terms in the license agreement".
8. Your download will start automatically, if not click restart below.
9. Save the file anywhere you want:
After downloading, run it and install your drivers. I think, you will be able to solve your problem.
