I have tried to update my windows 7 quite a few times. Each time it says that the update was successful then it says it needs to update. I tried re booting the computer and it locks up? How can I get the computer to understand that windows 7 was updated? Is my windows corrupt now?
Windows 7 Updates Not Updating?
Hi, Lloyd S Lebron you should check your update settings and be aware that there's a lot of updating to do after it downloads it will download again so go to your settings and choose only what is important to download. Click start after that in the search bar search windows update. When you are in windows update setting. You can see everything is there. Turn off your Auto update so it would not be a problem anymore.
