Windows 7 visual feature – settings not working
There is a visual option in Windows 7 which will slide the windows with (Windows + Tab) buttons together. I am using windows 7 operating system in my pc but unfortunately there is no use. I cannot not do it with my pc. I do not know why. Should someone know the settings in particular then kindly let me know.
Herbert Wellin
Answered By 45 points N/A #108757
Hello Herbert.
For Flip 3-D to work, Aero has to be enabled.  First thing you should check is your version of Windows 7.  Aero works in the following editions only:  Windows 7 Home Premium, Windows 7 Professional, Windows 7 Ultimate, and Enterprise editions,
If you have one of the above editions, check that you have an Aero Theme enabled.  Right-click on the desktop, select Personalize and pick one of the Aero themes from the list.
If you cannot enable Aero despite the above 2 conditions, it is possible that your graphics hardware or perhaps your system does not meet the minimum hardware requirements to run Aero.
