Windows 8, is apps back possible?
I use the windows 8 OS and i really will like to know if its possible to back up an executable file of the apps i downloaded on the windows store, like its being done in the android operating system. Is this also possible here?
Answered By 5 points N/A #127359
      Actually you cannot only do that on windows 8, you can also do that on windows 7. All you need to do is to download the software or tool which you can use to do that. The name of the tool is Zapback. This tool is use to back-up .exe files from your system.  You can back up .exe files that you want to back up. After you back-up you can recover that file with the help of the recover option. So if you want to back-up .exe files to your computer and want to retrieve again, this tool is the answer.  The size of this one is small and easy to use.
