Windows 8 browser problem (shutting down)
Hi All and Techyv Experts,
I install new Operating System Windows 8 Development preview beta version into my Hp Laptop.
I am having a problem with the Internet explorer because it keeps on shutting down when I am using it.
Please help me to fix this bug.
Thanks in advance
Amie Winehouse
Best Answer by lee hung
Answered By 75 points N/A #117589
Hi Amie,
Windows 8 Operating Systems only supports Internet Explorer 8 you can always updates your old browser into the new one.
This software as i have heard, cannot supports 3rd party plugins.
If this error cannot be resolve, is much better to install another Operating Systems like the older ones, Example Windows 7.
There are laptops specifically design for 1 Operating Systems just like my DELL Laptop before as i experienced it only be compatible with 1 Operating System and that is Windows Vista 32 bit, if you install other operating systems or even Vista 64 bit, there will be a problems with the driver like soundcard and graphic.
It will not work, unless Windows Vista 32 it. You can also research the compatible Operating System on your Laptop brand, so that it would not shutting down again.
Thanks,
Tony Stevenson
Answered By 0 points N/A #117590
 Windows 8 operating system is new and has not hardly faced to problems. But it is also possible that problem is in hardware of laptop.
You will try this solution:-
1 Format your system drive and try to reinstall your copy of windows 8.
2 If your windows are genuine then must star windows update and get newest update from Microsoft windows.
3. Install a good antivirus, so Windows system file would not crashed by any virus.
 4 go to company store and let him to check you system hardware that working properly.
 After All solution I think you will have no problem to your laptop.
Answered By 0 points N/A #117591
 You can also use different browser for browsing internet.
Answered By 0 points N/A #117592
To solve this problem
Go to Start Menu > after that Click Internet Explorer Menu > Click Tools Button > then Click Manage Add Ons button > below Add-on Type , Click Toolbars Extension > Under Show, to display a complete list of the add-ons that reside your computer, Click all add-ons >  next Click Currently loaded add-ons > Click Run without permission.>
To display only 32-bit ActiveX controls, click Downloaded controls > when you are finished ,
Click Close.
