sevenseven
Posted on - 08/16/2012
Last week i've got my hand on a developer version of windows 8. But as i am trying to burn it on a DVD I'm getting the following error message:
I am using ImgBurn.
ImgBurn
I/O Error!
Device [3:0:0] ATAPIÂ iHAS424Â B GL15Â (D:) (ATA)
ScsiStatus: 0x02
Interpretation: Check Condition
CDB: 2AÂ 00 00 02 9FÂ 20 00 00 20 00
Interpretation: Write(10) – Sectors: 171808 – 171839
Sense Area: 71 00 03 00 00 00 00 0AÂ 00 00 00 00 0CÂ 00 00 00 00 00
Interpretation: Write Error
                            Retry                Cancel
Please help.
Windows 8 dvd burning error on imgburn
Hello Stevenseven,
The I/O error in ImgBurn usually occurs due to lack of the Verbatim disk that is required. The following steps will help you fix this error with the using the Verbatim disk.
First, you will have to restart your computer.
And then you will open up Task Manager.
And then you will go to Processes.
After that close all unnecessary programs by selecting the program and then clicking on End Process.
Next you will run the ImgBurn without closing the task manager.
After that insert disk.
Go to the Task Manager Process tab and then right click on ImgBurn.
Set Priority to High, and then close Task Manager.
You can start burning now.
Carl
