Windows 8 error message has occurred
I tried to update the window but I could not update it. I am receiving an error message which you can see in the below attached image:
Hello!
If you want to get rid of this problem, you should follow these steps.
Step 1: Restart your computer from the upper-right corner. Click to the Settings > Power > Restart. After restarting the system, try to update by installing Windows updates.
Step 2:Â To download Windows Troubleshooter, choose Fix-It.
Step 3: When Windows Update Troubleshooter is completed, open it by swiping in from the right edge and then tap Search > Type Troubleshooting > Setting > Troubleshooting > System and Security > Fix problems With Windows Update > Next.
Step 4: Insert the Windows 8 DVD in the drive and repair the computer. Then choose Troubleshoot and select Advance Options. Click on Windows > System Restore > Next. Again, restart the computer.
Hope this would be helpful to you.
Thank You
Hi Walter E Laymon,
I think you are trying it manually but I suggest you that you should "ON" your Automatic Update. You should also need to clear temp folder of windows update. Follow this directory at the picture below:Â
Go to there and delete all. After clear that you should restart your automatic update and run the Automatic Update.Â
Hello Walter ,
