Alan Farrer
10 points
Posted on - 08/09/2012
I am installing Windows 8 using Oracle Virtual Box. All the necessary configuration has been done. But I've got this following start up error display:
Your PC needs to restart
Please hold down the power button
Error code 0x0000005D
Parameters : 0x03062502
Any Idea how to resolve this problem?
Amy Shum
5 points
Windows 8 installation problem using Oracle Virtual Box
Hi Alan,
You can fix up the issue by rebooting your machine. Before booting up of the operating system, get access to the BIOS by pressing F2 (may be other combination depends on what brand of motherboard you are using), anyways.
Now point to Advance menu and search for CPU Configuration or similar tag as of differences of motherboard manufacturing setup.
Thereafter, look for No-Execute Memory Protection option, set it Enable as by default it stays as Disabled, and in order to carry on with your installation, you need to Enable it.
Eventually, save and exit the BIOS preferences. This will help you out installing Windows 8 smoothly.
