What are the distinct features of Windows 8 Pro 64-bit Edition as compared to the features of Windows 8.1 Pro 64-bit Edition? What do these softwares share in common from the technical point of view? What can you say has being the level of the technological development from the past to date considering these two Windows Operating System versions?
Windows 8 Pro 64-bit Edition Vs. Windows 8.1 Pro 64-bit Edition
1. Windows 8 pro: This edition can compare with windows 7 professional and ultimate. It is mainly targeted business users and enthusiasts. It is providing all features of Windows 8. In addition that it includes the ability to receive Remote Desktop connections, the ability to participate in a Windows Server domain, Encrypting File System, Hyper-V, andVirtual Hard Disk Booting, Group Policy as well as BitLocker and BitLocker To Go. Windows Media Center functionality is available only for Windows 8 Pro as a separate software package.
2. Windows 8.1 pro is providing variety of features such as encrypting your data, to connect easily with company network, access one pc from another etc.
3. If your system is running with windows 8 pro, then no need to buy 8.1 pro, you can easily upgrade your system from Windows 8 pro to Windows 8.1 pro.
4. Windows 8.1 aims to cover all complaints of windows 8 users. It improved Start screen, additional snap views, additional bundled apps, tighter OneDrive (formerly SkyDrive) integration, Internet Explorer 11, a Bing-powered unified search system, restoration of a visible Start button on the taskbar, and the ability to restore the previous behavior of opening the user's desktop on login instead of the Start screen. Windows 8.1 also added support for such emerging technologies as high-resolution displays, 3D printing, Wi-Fi Direct, and Miracast streaming.
