PhilipBoyle
Posted on - 09/20/2011
I have installed Windows 8 64 bit trial version seven days ago. It all worked good until yesterday.
When I started the computer I got an OS error with a blue screen C: Windows / memory.dmp SYSTEM_THREAD_EXCEPTION_NOT_HANDLED.
If anyone knows what it is I would appreciate any suggestions?
Your PC ran into a problem that it couldn't handle,
and now it needs to restart.
Windows 8 trial version blue screen
This is not already a perfect version of Windows 8 because it is said that it will release on 2012. This might only be a beta operating system and ready to be tested by few users, so that they can get feed backs from you.
If you installed it directly to your hard disk, then you did a very terrible mistake my friend. You should have tested it to a VMware so that it will have no problem even if that system breaks.
Unfortunately, there is no significant fix provided by Microsoft to fix this error. All we can do is wait for the stable version of the operating system. Try to install an old version of operating system for now.
