Windows 8.1 top 10 features
Windows 8.1 top 10 features, heard its going to be released next month. What can we expect?
Exited to see the new features.
Thanks
Thanks
Windows 8.1 has many new features and plenty of updates. Below are my pick for top ten.
Windows is going to release the windows 8.1.The top ten features are as follows
1) Closing of the application can be done easily
There is no small close button here.Instead you have to swipe from top to the bottom of the screen
2) Greater wireless support
Support NFC print setup,wireless printing and better support for wireless display
3) 3D printing support
4) Extensive SkyDrive integration
SkyDrive will be integrated right into windows explorer so that accessing the SkyDrive documents from the desktop is more easy
5) Good privacy management
If you don't like the idea of an advertiser tracking your online moves,you can decide how much information Microsoft
Shares
6) Swipe left or right to see your open windows
7) See shortcuts on the onscreen keyboard
8) Snap views and better multi monitor
Users can run multiple apps in the foreground with snap
9) Refreshed Xbox Music
It allows users to stream over 30 million tracks for free
10) The start button returns
