Windows Activation Process Throws 0xc004f00f Error, Help Me To Resolve This Error
Describe about the 0xc004f00f error? Why 0xc004f00f error occurs and describes the methods to resolve the error?
When the user enters an invalid product key or enters the product key from another Windows edition to different Windows for the activation, then it gives rise to 0xc004f00f error. Windows 10 Activation Error Code 0xc004f00f occurs when the windows activation is done. The steps to remove Activation Error Code 0xc004f00f in Windows 10 are as follows:
Step 1: Click on the Start option.
Step 2: Go to Settings.
Step 3: Click on the Update & Security in the settings tab.
Step 4: Select the Activation option and click on the Troubleshooter option.
Method 2:
Activate the Windows using SLMGR.
Step 1: Hold Windows Key + R to open the run dialog box. Give all the permission that appears on the screen.
Step 2: Open the command prompt and type the following commands:
• Slmgr /ipk <Windows Key>
• Slmgr /ato
Restart the system, and the error will be resolved.
Notifications
