meetrajib
Posted on - 10/02/2011
After enabling IP Virtualization (per session) I am unable to access Active directory tools. I started getting the following error:
”Naming information cannot be located because: The network path was not found. Contact your system administrator to verify that domain is properly configured and is currently online."
How to fix this issue?
Windows Active Directory network issue
To solve this problem install active directory properly. Give a perfect domain name for active directory. Use @, .com etc for creating domain name. Then create user under this domain. Give IP address for every user. Then finish user creating process.
Now in user’s computer configure its login system so that it can log in under new domain. In order to do this just go to my computer > properties > Computer name. In this tab there is a option named to rename this computer or join a domain click change. Click on this button.
Now this box will come.
Here in member of option click domain radio button then give domain name perfectly. After that search for new domain. If available then restart computer and log in with new domain.
