Windows can’t verify the publisher
Just recently, I had a trouble when I delved through with the GIGS and GIGS storage file. I was trying too hard only to find out that the file don’t actually exist. I have applied everything I know, but it seems not good enough. I tried manually pulling up “File/Run” as “Administrator/Server Properties” to actually get the list of my drivers. But then, an error message just popped out. How may I be able to get a way with this? I guess, I have moved the MSI files for both bit versions, 64 and 32, respectively, out from TEMP folders already and even removed all the installers. What can possibly be the problem? This error makes it harder for me. I really need help.
Windows can't verify the publisher of this driver software
Don't install this driver software
You should check your manufacturer's website for updated driver software for your device.
Install this driver software anyway
Only install driver software obtained from your manufacturer's website or disc. Unsigned software from other sources may harm your computer or steal infermation.
