Frederick
Posted on - 08/04/2011
I have a problem with Windows XP and this is my latest experience. I finished up my installation of Windows XP sp3… after I turned off the CPU and I unplug the DVD ROM, when I restart the computer it will not boot into Windows but restart continues.
This makes me wonder, after I plug it back to the DVD ROM. It can boot Windows and there is no master in DVD. I already uninstalled and reinstalled 3 times. But still problematic as above.
Windows cannot boot, unless there is a DVD rom
Did you fix the jumper setting in your DVD ROM? At the back of your DVD ROM there is a jumper setting one is Master, two is Slave, and next is CS.
Please check the jumper settings and put the jumper into Slave setting.
Visit this site for more information:
Master, Slave and Cable Select HD Jumper Settings
Thank you hope it helps.
Regards;
henjobeder
Thank God.. Like what you said I need to be setting the jumper. Thanks a lot Henjobeder.
