I have windows xp with movie maker 2 installed. I know how to join avi files in that application. But now I want to do this in the console. I'm writing a Batch script that will automate this, but I can't seem to find a command to do this for me.
Windows console join multiple avi together
Here you want solution for making automatic Batch script through movie maker 2 by using windows xp. For some difficulties you cannot make automatic Batch Script on movie maker 2.
By using some sort of advanced tools you may can make it automatic easily by movie maker 2.You can use Automation Batch tool 3.2.2 for this purposes.
After install it I hope you will get your solution easily.
