Hello there,
During the install of Windows 7 on my laptop this error appeared and terminated the install. Even the error said that changes won’t be saved my laptop is still broke. Any solution for this error ? How can I install this Windows properly ?
Thanks!
Windows Setup
The installation was canceled
Any changes made to your computer won’t be saved.
Windows could not apply unattend settings during pass [offlineServicing].
OK
Windows could not apply unattended settings during pass offlineServicing
If you are upgrading your operating system to Windows 7 from either Windows Vista or Windows XP, you should make sure you meet all the requirements. If you are already running Windows Vista and wish to upgrade to Windows 7, you shouldn’t have any problem. But if you’ll be upgrading from Windows XP, you should meet the following requirements: 1 GHz or faster processor either x86 or x64, 1 GB minimum for x86 and 2 GB minimum for x64, 16 GB free disk space for x86 and 20 GB for x64, and a video card that supports DirectX 9 with WDDM 1.0 or higher driver.
Additionally, if you’ll be upgrading from Windows XP, you should be visiting How To Upgrade XP To Windows 7. There is no direct upgrade method of upgrading Windows XP to Windows 7 and you need a lot of customization before you achieve this. In your case, don’t start the Windows 7 installer in unattended mode since it is already causing an error.
If you are using Windows Vista, just run the Windows 7 setup CD normally and upgrade your operating system.
